Dorman aluminum line repair kit?
Dorman part no 800-600
Has anyone tryed or used it?
Was wondering if it was any good or if it will hold up to long term use?
Thanks Crunch
Crunch if you want to repair that hose yourself and have the ability to have the hose sections crimped. Look at the weld on fittings and aluminum brazing rod we offer. Depending on size these are the fittings I would use.
WELD ON #6BL 3/8' TUBE ALUMINUM OD FIT
Fitting Size 3/8
Hose Size #6
Item # 35-B6601-A
WELD ON #8BL 1/2' TUBE ALUMINUM OD FIT
Fitting Size 1/2
Hose Size #8
Item # 35-B6602-A
WELD ON #10BL 5/8' TUBE ALUMINUM OD FIT
Fitting Size 5/8
Hose Size #10
Item # 35-B6603-A
WELD ON #12BL 3/4' TUBE ALUMINUM OD FIT
Fitting Size 3/4
Hose Size #12
Item # 35-B6604-A
Fitting link.
42-00110-10 - Aluminum Braze Rod
Thanks TRB/Tim
I will look into that.
Can the be use to aluminum brazing rod be used with the oxygen/sedline setup?
Thanks Crunch
That's what we use.
Thanks for the info. TRB
Crunch
Should not be a problem for you. Few practice runs and I think you would get the hang of it.
