Year: 1998
Make: VW
Model: new beetle
Engine Size: 1.9L
Refrigerant Type: 134A
Ambient Temp: 90f
Pressure Low: ??
Pressure High: ??
I need to replace the shaft seal, will the pressure pop the seal out when I unlock the circlip? I got the tool to drive the seal in(FJC 7615).
thanks for input.
wrench
diesel is music, music is noise!
You mean the pressure of the system? You have to recover the refrigerant in the system before you can start removing the shaft seal. Once that is done, you can remove the compressor, or if it is possible to do on the car, replace the shaft seal. Then once you get it reinstalled, vacuum the system and recharge it.
