Year: 1998
Make: Dodge
Model: Durango
Engine Size: 5.2l
Pressure Low: 120
Pressure High: 150
Can you guys tell me if this sounds right....1998 dodge durango blowing hot air. I checked the system with gauges and with the A-C- running and compressor clutch engaged, I read about 120 on low side and about 150 on the high side. System doesn't appear to have any noticable leaks. This particular system apparently has a drier and expansion valve. My thoughts were that the expansion valve was stuck wide open. ???? What do you guys think...
I think your gage set is wide open.....
Are you sure you have the valves closed and compressor is running --center hub turning?
If you answer affirmative, then your compressor is toast
the compressor is running and it is engaged...i was thinking that my gauges were closed...and I am assuming that you have to have them closed at that point to measure properly?
So if my gauge valves were open...why would it show that high on the low side...
If the compressor is toast...what part of it goes bad? It's able to have a high pressure....I am just wanting to learn more about it...could you explain how it can still have such a high reading on the high side?
On a hot engine that 120 psi could be static pressure-- the 150 psi could be static pressure with some gage error mixed in-- Heck, you may even have a broken shaft, compressor not even pumping- and all you are seeing on your gages is static pressure- influenced by a hot day or a hot engine. Does pump turn very easily? little or no resistance? Was engine hot when testing-- check system pressure when it's cool out.
thanks for your reply....the compressor does turn very easy....and the engine was a cold engine. If a compressor had a black death, would it turn easy?
jg,
Early Durangos (made in Delaware down the road from DuPont) had a warranty problem with stuck expansion valves (made by Eaton/CC) in the optional rear auxiliary evaporator, which resulted in compressor failure
The preferred rear valve is made by FujiKoki
hotrodac
Edited: Thu June 10, 2010 at 1:45 PM by ice-n-tropics
