Year: 2001
Make: toyota
Model: tundra
Engine Size: 4.7
Refrigerant Type: r134a
Could I take an old R134a tank, and weld a fitting on it, so I could hook a vacuum pump up to it, to evac my system?
Whaaaaaaaaaaaaaaa?
You will need a vacuum pump, a gauge set and hoses. What's the purpose of the tank?
Ken Kopsky
Custom Car Works
I think original poster is inquiring how to RECOVER refrigerant from his system.
The short answer would be: yes. You'd need to cool the recovery tank, and pull a good vacuum, then attach to your system. As the refrigerant comes over into the tank, the cold temperature makes the refrigerant condense to a liquid, so there's still vacuum in the cold recovery contaner, and the process continues.
I've done similar using a metal cannister which holds about 3 pounds refrigerant.
Edited: Fri June 25, 2010 at 8:29 PM by Cussboy
Cussboy, Yes that is what I am wanting to do. Don't want to release freon into the air, so I thought I could trap it in a tank. I would then take the tank to a reclamation center. I have a 5cfm vac pump, would that be enough? Should I use dry ice, or regular ice to chill the tank?
