Year: 2005
Make: buick
Model: Century
My ac is blowing out the floor vents only! As I try to change the air selector from MAX to VENT to Bi-Level, etc...nothing happens. I hear it might be a vacuum leak..but I am not sure where to begin! HELP!
I think on those later models, the system is all electric, and complicated (CAN bus). Do you hear a motor turning at all when you change the selector? Do that with the key on but engine not running so you can hear better.
The blower works in all speeds...but it refuses to change the air flow into the ac vents...or defrost, bi-lev, etc
Take it to someone who owns a Tech II scan tool- it will report the code(s) and you can follow the analysis tree from there.....
