Year: 09
Make: pontaic
Model: G6
Engine Size: 2.4
When first starting AC the compressor makes a noise like a coffee grinder for 10 seconds some times, then stops. The car was in for a oil change and the dealer heard the noise.
The compressor is going to be replaced, been wondering what could cause this, 13K miles.
Liquid refrigerant...the new compressor will most likely do it as well......
slls,
My compressor sounded somewhat like an old coffee grinder this morning. It was the clutch chattering intermittently, caused by a loose wire connector on the compressor.
When the connection was touching and not touching fast, it made the clutch chatter.
Not saying that is what is causing your noise but it is something to check when there is an intermittent noise.
Quality is never an accident it is always the result of intelligent effort.
Thanks for the reply. Don't understand your reply, over charged ? system design ?
