i'm looking into getting a recovery machine and need some help on deciding which one and what kind...I need to be able to recover the refrigerant and make it reusable for either the same system or other systems...I have seen the "kits" like the 69500 - RecoveryMate
on ackits.com. will this kit allow me to do what I need, it says it removes moisture, debris, and oil which sounds good but if it removes the oil how do you know how much oil to put back in...it doesn't remove all of the oil from the system does it ?? I will only be using the recovery machine a couple of times a year so I don't need a 3,000 dollar unit just something simple to get the job done
Edited: Sun June 12, 2011 at 10:58 AM by bigred1500
This is option I suggest, 69100. The 69500 is an addition to the 69000. Most R ^ R machines will have an oil separator. As you will pick up "some" oil in the refrigerant.
