Hi, I have a A6 compressor with side to side shaft play of .005-.010 inch which I suspect caused a new shaft seal to fail. I'm looking at replacing the case bearings in the gut pack. Are these parts available and how does the gut pack come apart? I have the unit disassembled but not seeing how the gut pack is disassembled. Unit was in a 72 Monte Carlo. Thanks in advance.
Figure out how the gut pack separates. It's just pressed together with some locating pins. Tap the halves apart and you have full access to the interior parts.
