gauge readings
Posted: Mon Oct 12, 2020 5:12 pm
by penguins25
my ac in my 08 mgm doesnt work on normal ac
it does work somewhat on max ac
i put my guages on it and this is the readings
low side read 125 constant
high side was going from 200 to 300 cycling
Re: gauge readings
Posted: Mon Oct 12, 2020 7:33 pm
What exactly is an "mgm"?
It sounds like a coupler malfunction. Low side.
Re: gauge readings
Posted: Mon Oct 12, 2020 7:40 pm
by penguins25
mercury grand marquis
Re: gauge readings
Posted: Mon Oct 12, 2020 7:45 pm
by penguins25
whats a coupler?
Re: gauge readings
Posted: Tue Oct 13, 2020 2:28 am
by Dougflas
The low side fitting on the hose does not sound as if it has the proper connection.
Re: gauge readings
Posted: Tue Oct 13, 2020 3:14 am
penguins25 wrote:my ac in my 08 mgm doesnt work on normal ac
bohica2xo wrote:What exactly is an "mgm"?
Penguins, you assumed we would know what "mgm" means????
Re: gauge readings
Posted: Tue Oct 13, 2020 9:14 am
by penguins25
please help yall
i really want to fix my ac and dont know where else to go
new readings
Posted: Tue Oct 13, 2020 3:21 pm
by penguins25
just went out there and put the gauges on and here is what i got
low side 75-150
high side 300-500
both sides cycle back and forth through them numbers
my ac blows cool not cold
edit:
these readings were taken on max ac
theres a normal ac setting i can put it on but the ac doesnt blow as cool on this setting
i can go take anorther reading on normal if this would be helpful
Re: gauge readings
Posted: Tue Oct 13, 2020 5:29 pm
by Dougflas
Readings are too high. Spray the condenser with a water hose while monitoring the high side pressure. Does it drop like a rock? If so, start by checking airflow across condenser. Check the cooling fan also. If the high side drops, does the low side drop also?
Re: gauge readings
Posted: Wed Oct 14, 2020 2:59 pm
by penguins25
i put the gauges on and got the water hose
its doing the exact same thing as before its going back and forth between
low side 75-150
high side 300-500
the water on the condenser does not drop the readings
