Turning on AC or Heater caused idle to drop severely
Posted: Wed May 18, 2016 6:26 am
				My car is a 2003 Honda Accord. My kids drove it but have moved out and have lives elsewhere now. I charged the AC with R134 a few months ago and it got cold just fine. But, the idle was fluctuating wildly even without the AC on, so I ordered an IAC valve. I came back from a trip and some other chores and finally replaced the IAC valve and now it idles just beautifully. BUT, when I turned on the AC, it got cold but the idle dropped so low it seemed like it would die. So I gunned it a little to get the idle up. I thought it needed to be run after sitting for several months, so went for a ride, and turned the AC on only after I was moving at 30mph or so. Very quickly the rpms dropped like it would die and I could hear gas venting under the hood. I turned the AC off and the car ran fine. I think the venting sound was the refrigerant.
I am not sure that maybe this is the compressor seizing up?
Or, from what I read here, could it be that before I recharged it, all the refrigerant leaked out and air got into it? I did not have it vacuumed out. It had been charged by a shop 5 years ago and it last that long so I thought it would be no problem to charge it myself this time. If air got in the line and now mixed with the R134, could that cause the idle to drop to the point where the engine might die when I engage the AC?
The same extreme low idle occurred when I turned the heater on instead of the AC. How could that be happening? That shouldn't affect the compressor or the R134 and any air in the lines, correct?
Thanks for your help
