Upgrading (and remounting) a Vintage AC system
Posted: Mon Oct 22, 2018 6:06 pm
Hello all-
I just recently bought a 1967 Volvo P1800 with AC. Back in those days, 'factory air' consisted of an aftermarket unit that was installed by the dealer. In this case it was a Frigiking unit found on a lot of Benz/BMW/Volvo cars from the 60's and 70s'.
The unit actually still works and is still charged with R12 judging by the fact the valves are still R12 style.
The thing is, I'd like to remove it. The main reason is that it hits my shift hand and my right leg while I'm driving.
Also, the compressor is a beast and I'm sure it's robbing valuable HP from an already underpowered car.
But I'd still like to have AC in my car, so here's my plan and I'd welcome any feedback on it.
1. Evacuate the system of R12. Where do I get this done? Any AC shop?
2. Remove the underdash evaporator, the compressor and the drier unit.
3. Relocate the evaporator to a spot just behind the rear seats between the shock towers. It would fit perfectly here and a custom vented cover would cover it nicely.
4. Remove the switches from the Evap unit and mount them under the dash by running longer wires.
5. Replace the compressor with a Sanden unit.
6. Install a new receiver/drier.
7. Install longer hoses to hook it all up.
8. Recharge with R134a or Feeeze12
Now, if you look at the compressor image, you'll see that this system doesn't use proper fittings, just hose clamps that seem to be these.
So to hook up old and new parts, I'd either need to use fittings like these and use standard hose clamps, or try to find flat fittings and use the AC hose clamp. Or buy the not-so-cheap press-flitting tool and make the proper ends to mate to the Sanden compressor and the drier.
So, experts out there, does this sound like it will work? Would R134a work in a system with an old evaporator and condenser and these old style hoses? Or should I use Freeze12?
