2013 Nissan Frontier SV Crew Cab intermittent AC at idle and constant highway speed
Posted: Sat Jul 16, 2022 6:26 pm
by ACHelpNeeded
2013 Nissan Frontier SV Crew Cab intermittent AC at idle and constant highway speed - if at idle for 5-10 minutes (e.g. eating lunch in a parking lot) the AC intermittently blows warm after a few minutes of idle but cools fine when driving again. Also have seen a similar intermittent issue with long drives at highway speed when at a constant speed - slowing down/speeding up seems to get the AC cooling again. I just replaced the evaporator thermistor and the problem remains. Any thoughts?
Re: 2013 Nissan Frontier SV Crew Cab intermittent AC at idle and constant highway speed
Posted: Sat Jul 16, 2022 6:45 pm
I'd want to check the clutch
gap. It should not be greater than .020.
Do a search on this site for 'clutch
gap'
It is a matter of removing one or more shims
Go here:
search.php?keywords=%22clutch+gap%22
This search also brought up the
gap between the condenser and the radiator, you can ignore those posts
And please remember that performance at idle will never equal that at speed
Posted: Sat Jul 16, 2022 7:17 pm
by ACHelpNeeded
With my limited understanding it seems the clutch gap would be more random or am I misunderstanding?
Posted: Sat Jul 16, 2022 8:36 pm
Likely completely different, but on my 1998 Frontier I removed an AC clutch shim to restore its intermittent operation, like 3 years ago. I didn't even need to remove the AC belt on my 1998 to do this !!! See posts starting with #72 here
https://www.clubfrontier.org/threads/19 ... 905/page-4
Posted: Sat Jul 16, 2022 10:06 pm
This youtube is not your car but gives you an idea
https://www.google.com/search?client=fi ... Px8yiqAo16
Start at 2:12
Cusser is the resident Nissan expert
