Does a home vacuum pump extract oil along with refridgerant?
Posted: Sun Apr 26, 2020 6:26 am
I am trying to follow the factory procedure for converting my 91 Porsche from R12 to R134a. I have removed the compressor and drained all the oil I can from the ports (there is no drain plug). I have a home vacuum pump and manifold set from harbor freight. They both work well but do not separate refridgerant from oil and I have no idea if oil is actually being pulled. Any assistance appreciated.
Factory Procedure:
Procedures
Retrofitting of air conditioning systems to refrigerant R134a:
Important :When working on air conditioning systems, observe safety precautions for operations on the air conditioning system and for handling the refrigerant (also refer to Repair Manual, Group 87).
1. Before starting retrofitting, check operation of air conditioning to see if additional repair operations are required on the air conditioning system (e.g. faulty piping, inoperative compressor and/or system leaks).
2. Connect recycling service equipment for refrigerant R12. Extract and dispose of refrigerant and refrigerant oil properly in accordance with instructions. Measure and make note of the refrigerant oil volume that has been drawn off.
3. Refill the system with the entire R12 refrigerant volume drawn off without the refrigerant oil.
4. Start engine. Switch on A/C system and run engine at approximately 2,000 rpm for approximately 10 minutes. Operate the A/C system to mix any remaining refrigerant oil with the refrigerant so that it can be drawn off.
5. Draw off refrigerant and refrigerant oil. Measure refrigerant oil volume and add to volume determined under item 2. At least 50% of the specified refrigerant oil quantity (see system specifications in brackets) should be removed from the system.
If insufficient refrigerant oil was drawn off or drained, proceed as follows according to the compressor type:
a) Compressor with drain plug:
Remove drain plug to drain refrigerant oil.
b) Compressor without drain plug:
Remove compressor and drain refrigerant oil at port connections.
c) Refit compressor.
6. Carry out any repairs that might be required on the air conditioning system (see item 1). Replace the receiver dryer (see chart) and install without any delay after removing the plugs. Replace O-rings and coat them with fresh ND-Oil 8 refrigerant oil.
7. To allow the R134a service equipment to be connected, fit the required adapters (angle valves or straight adapters, depending on space constraints) to the previously used connections.
New charge:
8. Evacuate system with A/C in maximum position. If system evacuation is successful, proceed with item 9. If not o.k, proceed with troubleshooting (leak) and repair.
9. Fill in fresh ND-Oil 8 refrigerant oil (for volume see charts) using service unit or external filling unit.
Note nly use new oil, used refrigerant oil extracted from an A/C unit must not be re-used.
10. Evacuate system again for approximately 1 hour. Run leak test in vacuum section (the vacuum generated must be maintained for approximately 2 minutes).
11. Fill with specified quantity of refrigerant R134a.
12. Run engine. Check for output and leaks at an increased high pressure of approximately 18 bar. To reach this high pressure, switch off the fans briefly by disconnecting the wiring plug.
Factory Procedure:
Procedures
New charge:
