Schrader Valves Leaking Down
Posted: Mon Jun 21, 2021 5:11 pm
by philipswanson
I was wondering if the Schrader valves used for air conditioning are any different than regular ole tire valves? Mine are both seeping over time down to zero.
Re: Schrader Valves Leaking Down
Posted: Mon Jun 21, 2021 5:14 pm
I'm under the impression that they are similar but different.
I'd get some for AC use.
Posted: Mon Jun 21, 2021 7:59 pm
Agree.
Are you using the caps that go on top of the schraders? They are your final seal
Posted: Mon Jun 21, 2021 8:46 pm
Depending on the vehicle. They have valve and cap groupings.
Posted: Tue Jun 22, 2021 7:38 am
by philipswanson
Tim, It is a motorhome with generic type fittings on the metal lines. A diesel pusher. Do these take special valves. Mine are leaking. My system is down completely and I have telltale oil in the fittings to the brim on both sides.
