Re: AC compressor problem
Posted: Tue Aug 02, 2022 5:12 am
by DetroitAC
We don't know you, can't tell if you are doing it correctly. What do you mean "tried to fill"? Can you provide more explanation?
Posted: Tue Aug 02, 2022 6:37 am
Was the leak fixed? It sounds very low on refrigerant so far.
Vacuumed down with what type of pump? One operated by compressed air?
Do you have a manifold gauge set? Or just the low side plastic gauge that comes with some of the refill kits. Did you add sealer?
Need more detail as Detroit mentioned.
