Yellow charge hose questions
Posted: Thu Aug 11, 2022 3:55 pm
by acnoob
Hello
I need to fix an ac issue on my car that has r1234yf
I bought this manifold guage set:
(Moderator removed link.)
question 1)
I notice these r1234yf does not have a purging valve on the yellow charging hose...is this going to be a problem when charging?
question 2)
are all r1234yf yellow charge hose left hand thread on the can side?
question 3)
are all r1234yf yellow charge hose a 1/2 female fitting on the can side?
Re: Yellow charge hose questions
Posted: Thu Aug 11, 2022 5:49 pm
OK, first, no links to auction sites are permitted here, please remove.
Tim, the site owner, and proprietor of ACkits.com, has excellent quality products at excellent prices. You missed an opportunity to get quality equipment.
Second, we do not do 1234yf in this shop, so we'll need to wait for JohnHere or someone else to come along. AFAIK all the 1234 stuff is L hand thread
Posted: Fri Aug 12, 2022 6:47 am
acnoob wrote: Thu Aug 11, 2022 3:55 pm
I feel for you !!! Remember, we were all "promised" that R134a was safe and the answer to all auto AC woes !!!!
question 1)
Why can't you just unscrew the hose fitting slightly/briefly at the manifold end to purge out air???? Like I did with R134a earlier in the week....
Posted: Fri Aug 12, 2022 8:25 am
question 1)
Cusser wrote: Fri Aug 12, 2022 6:47 am
OP, it's not a problem at all. In fact, I had the same concern when I started to deal with R-1234yf a few years ago.
My Manifold Gauge Set (MGS) is configured essentially the same as yours, with all three hoses
permanently attached into what appear to be 1/8" NPT threads in the MGS. Like yours, my hoses don't have the typical knurled thumb-screw fittings on the MGS ends that we're accustomed to seeing. Therefore, the yellow hose can't be partially unscrewed at the MGS to allow for purging the hose.
However, I soon discovered that my yellow hose has a check-valve in the end that attaches to the vacuum pump and/or the refrigerant source. Look closely at your yellow hose end (the end with the knurled thumb-screw), and I'm sure you'll find a check-valve in there as well.
The check-valve makes it unnecessary to purge the yellow hose with refrigerant (and waste some costly R-1234yf) as we've traditionally done with R-134a MGS's
not having a check-valve in the yellow hose. All the hoses in these particular R-1234yf MGS's—including the yellow hose—will be evacuated of air and moisture along with the MGS itself and, of course, the A/C system.
This presumes that you're not going to attempt "topping up" the system, which professional MVAC techs ardently discourage—and for good reasons.
On removing the yellow hose from the vacuum pump and subsequently connecting it to a refrigerant source, no vacuum will be lost and no air and moisture will enter the hose because the check-valve will prevent that from happening. So don't worry—there's no need to purge the yellow hose with this type of R-1234yf MGS.
question 2)
Yes. They're all left-hand 1/2" ACME threads, including the can "tapper" valve if you use one.
question 3)
Yes. Those, too, are left-hand 1/2" ACME threads. This is done to prevent inadvertently connecting R-1234yf hardware to R-134a hardware and mixing the refrigerants.
Posted: Fri Aug 12, 2022 8:30 am
Always good stuff to learn on this site. Like avoiding vehicles with 1234yf !!!
Posted: Fri Aug 12, 2022 8:36 am
I definitely hear you. The cost of R-1234yf alone will cause people to shy away.
Posted: Fri Aug 12, 2022 10:09 am
Once some of our racer friends learned that Miles and I were not going to service 1234yf cars, they actually sold their daily drivers and got used cars that were still 134a.
Have no fear, in a couple of years the EPA will ban 1234yf and come out with another refrigerant....they like to play with the numbers in Campbell's alphabet soup
Posted: Fri Aug 12, 2022 11:28 am
by acnoob
JohnHere wrote: Fri Aug 12, 2022 8:25 am
question 1)
question 2)
question 3)
thank you very much for your thorough response!
I bought a r1234yf can tapper and the threads are 1/4" sae threads. Of course that didnt fit.......this has been so frustrating and confusing getting information. I need to buy another r1234yf can tapper now that has 1/2" acme thread.
I did notice a small valve at the end of the yellow charge hose....well....thats one less thing i have to worry about.
I appreciate your response!
Posted: Fri Aug 12, 2022 2:59 pm
acnoob wrote: Fri Aug 12, 2022 11:28 am
Hmmm...I wonder whether the package was mislabeled or something.
When looking for another one, be sure of which design you want: Piercing type or self-sealing can. I'm sure that Tim can get you either one.
Posted: Fri Aug 12, 2022 9:51 pm
by acnoob
JohnHere wrote: Fri Aug 12, 2022 2:59 pm
My yellow charge hose is a 1/2” threading.
Question:
I bought r1234yf PAG dye but my car 2019 CRV says it uses POE oil. Is it a problem to put PAG dye in this ac system?
