94 Suburban K2500 AC help
Posted: Sun Aug 14, 2022 12:20 am
Looking for some AC expertise!! I mean I need an air conditioning wizard!
I have a 94 K2500 Suburban with rear heat and air—rear controls. Old school fan clutch.
Brand new compressor, condenser, accumulator, front orifice tube, fresh o-rings all around, rear expansion valve, compressor mounted high pressure switch, accumulator mounted low pressure cycling switch, 11 oz PAG 150, and 66 oz R134A. Entire system has been flushed front to back. Sensing bulb clipped and secured to suction line at the rear evaporator.
3 things that were not replaced—condenser mounted high pressure switch, front evaporator and rear evaporator, all lines.
Pulled 15 minute vacuum on system to check for leaks, then pulled vacuum to roughly 29 below for an hour and 45 minutes. System held vacuum with manifold valves closed for over an hour.
On startup, both suction lines going into compressor get cold. I can’t put my hand on the front evaporator (the front air box under dash has not been opened), but the low side coming out of evaporator and into and out of accumulator is intermittently cold and back to ambient temperature. Rear evaporator is cold. Rear air box is open, so we don’t currently have the fan running across the rear evaporator. Will close it up next weekend.
Low side pressure is 55, high side pressure is 295-300. Ambient outside temp 95.
Air blowing out of vents is roughly 60 degrees in the front. No air out of the vents in the rear system since the rear air box is still open and fan is not currently installed.
We held RPM at 1800 for roughly 15 minutes to watch temps and pressures. At one point pressures on low side dropped to roughly 40 and high side was at 400!
We then left the motor at idle and went inside for a bite to eat with front AC running full blast and rear unit off. Pressures were at their new normal of 55/300.
Touch test of suction lines at compressor front suction at roughly ambient temperature and rear line cold.
I’m stumped. Why is the front unit cold/near ambient temp intermittently?
What gremlins do I need to be chasing at this point?
