Insulate high side liquid line?
Posted: Tue Feb 28, 2023 3:54 pm
Hi All,
Long time reader, first time poster here. Until now I have always been able to find answers to my questions using the search function, but I guess this one is a little unusual...
I have an early C4 Corvette which has been converted to right hand drive as per the requirements of my country.
As a result, the evaporator is now mounted on the LHS of the firewall and the liquid line ex condenser and the return from the evap are now plumbed across the front of the motor in the path of the hot air from the radiator/fan.
I wondered if this was hurting performance. As an example, at idle on a ~80F day with the condenser fan running, the liquid line leaving the condenser is at about 86F, but after crossing the engine compartment to the evap, it picks up heat and measures about 114F just before the orifice.
Will this hurt AC performance? Is it worth insulating this line?
The high side has always been a bit higher pressure than it should be and I think this might be contributing, is this possible? - due to the extra length, but mostly the additional heat? The high side port is on the 'hot' end of this pipe, just before the orifice.
Many thanks for your expert input!!
