85 RX-7 r-134a conversion
Posted: Sat Jun 03, 2023 8:51 am
I've been working to convert my 85 RX-7 with factory air from r-12 to r-134. I first checked it's integrity and found it held vacuum nicely for 30 minutes.
I put in about half a bottle of Ester100 oil through the high side hose while pulling a vacuum with the low side and spun the compressor by hand and it immediately spun smoother, then let it pull a vacuum for another 30 minutes.
Going off the label on the Nippendenso compressor, it originally held around 2+lbs of r12, I understand you'd put in about 75-80% of that with r-134.
I put one 12oz can in and the compressor came to life and it started cooling inside the car but not great. My confusion is that with only 1 can, the low side pressure was already at 55 psi at about 85* F, which is what most charts list as the proper charge. When I started putting the second can in, one of the lines coming off the condenser failed.
I will replace the line and install a new drier, but I'd like to prevent this from happening again. The compressor label shows a much higher minimum low side pressure than what I've seen on most r/12 or r/134 pressure charts, at least at usual temps. Does that high of a low side pressure seem right or should I stop adding refrigerant at 55 psi, marginal cooling would be better than none.
