Sticking TXV?
Posted: Tue Apr 30, 2024 8:42 pm
Hi Guys,
I'm helping a friend sort out a problematic system.
This is a cobbled together system in an early Mustang.
It uses the original under dash evap, but everything else is custom. Compr. is a Sanden, condenser is new and huge.
When first started at idle, the pressures settle to 25/150 on a 70F day and it blows 44ish out the vents.
As soon as I raise the rpm above idle, the pressures go to 10/250-275 and the vent temp climbs.
If left to idle after being at 1800rpm the high side stays over 200 for quite some time.
It definitely has a low charge, but I suspect any more refrigerant would shoot the high side to the moon.
I forgot to look at the equalization time when shut off.
Feeling the in/outlets by hand, the condenser is doing a good job.
I'm thinking the old TXV is not working properly, that that seem reasonable?
Although there's a bit of a story regarding the guy who made the hoses......
Apparent he did half and returned a week later because he didn't have the correct fittings on hand. During this time he apparently left the drier open...
I know it needs replacement because of this, but could a moisture saturated dryer cause enough restriction to cause these symptoms?
I could not feel a temperature drop across the dryer, but am unsure if that's a valid test.
Can anyone provide any advice as the the possible problem and any further test methods before I open it up to replace the TXV?
Thank you all for your help
