Fan does not bring down high head pressure
Posted: Wed May 22, 2024 11:23 am
by Swedal
Recharged a Audi A6 2009 just now. Head pressure was high at 330 PSI at 80 ambient temp. The fan kicked in and ramped all the way up to full speed and sounded like a jet taking off but it did not manage to bring down the head pressure. Usually you will se the pressure drop as soon as the fan ramps up. I suspect a clogged TXV or other blockage. Low side was ok at around 40-45 and it did cool decently. Is this a bad TXV or a blocked condenser (air side)? But a bad condenser would react more to increased airflow right?
Re: Fan does not bring down high head pressure
Posted: Wed May 22, 2024 5:04 pm
Both of the pressures are too high. I'm surprised you get any cooling with a low side of 40-45 PSI. A reading of ~45 PSI means an evaporator temperature of ~50°F and center vent temperatures even higher than that--hardly adequate for comfort on a hot day.
Try misting the condenser with a garden hose and nozzle to see whether the pressures drop.
How did you recharge it, by weight or by pressures? We want to ensure that the charge amount is correct. Did you evacuate the system before recharging it? Did you replace the accumulator?
Posted: Fri May 24, 2024 2:03 pm
At what engine rpm did you get your gauge readings? Idle or 1800? S/b at 1800.
John’s questions are very relevant, sounds overcharged from here.
What was the reason for re-charging the system
Posted: Sat May 25, 2024 8:05 pm
If I recall correctly, I believe this car has a variable-displacement compressor with an electronic control valve and is direct drive (no clutch). It's possible that the control valve failed and is causing the pressure irregularities and poor performance. Consider changing the control valve first before disassembling the rest of the system.
