Custom AC project - general feedback and condenser selection
Posted: Fri Jul 26, 2024 2:34 pm
Project:
Custom AC installation in a 1993 Mazda RX-7 with non-standard components and non-standard heat exchanger orientation aka "V-Mount" radiator and intercooler.
I've machined custom mounts for a variation of the NipponDenso SCSA06C compressor. I had a slow leak in my original one/previous iteration of this configuration and suspected the original compressor was leaking/needed a rebuild, so I figured might as well move to something designed for R-134a. Hopefully, this compressor isn't going to be a step backward, as it is much smaller than what was in there and I should have picked something else.
Q1: Request for comments on this compressor before I get too much further into building stuff. This is a small 2-seat sports car cabin. It seems like it should work for my use case from the other listed applications in the ND catalog that have used it.
Q2: Is there a source for generic compressor pad mounts/line components aside from OEM lines for this compressor? I see some pieces that adapt from something that looks like this pad to standard #6/8/10.
I would like a condenser that covers the entirety of the custom radiator I'm building as a sacrificial part for any potential impacts from hard road debris. The car will see usage at road racing circuits. I'm not getting any younger, so, having a cool cabin while waiting on the grid for my track session is getting to be less of "tough it out, buttercup" and being smart about having a less tired driver (especially when wearing a driving suit for fire protection)...
Some folks seem to use the RX-8 condenser but I have 16"x28" of radiator core that I want to protect, which looks like it might leave me about 2" unprotected with it being 14" tall. I also figure that having a larger condenser would help, as some say the RX-8 AC can be anemic when it gets really hot (2" taller is 15% more surface area).
Q3: The NipponDenso AC component catalog shows condensers with the dryer integrated as having a "supercool" section. Is there a significant efficiency/advantage of this design over a standard parallel flow and an external dryer (I have room to fit but it adds extra plumbing work)? I've found a 16x24" generic dryer integrated condenser I could use, but I'm trading some potential condenser surface area for the integrated dryer...
