Reusing R-134 in same vehicle
Posted: Mon Sep 23, 2024 5:01 pm
Hello,
Few questions…
I have 9 vehicles I take care of (4 I drive, wife has 2 and 3 kids each have cars). Most are older from 2002-1016. I do all my own maintenance and have since I was a kid. This is not my profession. I’m on this forum because I have always taken care of my own AC issues. Recently I purchased a Mastercool 69110 recovery machine, Snap-on manifold and a TIF9015 electronic scale. These are all used items. I already had an older manifold set that the knobs have fallen apart and a vacuum pump. It was time to be more professional with my AC work…..
Generally my approach has been to remove R-134 from the system, evacuate, see if it hold the vacuum, then replace the R-134 with the spec for the car. So far I haven’t had to replace any parts over the years. Just lucky I guess.
I’m new to using the Recovery machine but I think I fumbled through it. I used the Recovery machine on my 2002 today and pulled all the R-134 into the 30# tank. I pulled about 16oz out and spec charge is 600g or 21+ ounces. I evacuated the system. Since I needed another 5+ oz of R-134 my solution was to add 5 oz to the 30# tank. I then added that back to the system directly into the manifold. The AC works great. I evacuated the empty tank and put everything away for the next job. Last summer both my wife’s vehicles had issues and this was my approach….minus the recovery machine…
First/Second question: Is there a better way than my plan to add the shortfall of R-134 to the 30# tank? I didn’t use the recovery machine to pump back in the vehicle. Is that the correct approach? My reuse of R-134 is limited to reintroduction into the same vehicle I pulled it from to be clear. I am certainly not authorized nor need the larger tanks of R-134 so I’m limited to the 12 oz variety.
Third question: The scale appeared to be kind of flaky. My initial pull from the car the gauge went up steadily but later when the rate was slower it appeared the scale would stop and show no progress. I’d lift the tank and set back down and the extra weight would show up. This was especially annoying putting the R-134 back in the car and the scale would stagnate and show nothing happening only to lift the tank and reset and the scale would be higher than where it stagnated. I eventually transferred the correct amount. Anyone have experience with this scale? Is this normal? It’s just annoying when the scale stops. It’s like when the rate of transfer drops below a certain value it ceases to sense the change. Just wondered. I thought about buying a new scale but I think i can make it work.
Thanks in advance!
Few questions…
Thanks in advance!
