Advice on how to flush after compressor failure?
Posted: Tue Feb 11, 2025 8:41 am
Hello,
I am a DIY'er and experienced a compressor failure on my truck last year. While I do replace the receiver dryer, I cannot really replace every other component in the system to get the dreaded black death crap out of the system. So now I am faced with another compressor replacement.
I am using an air conditioning Pipeline Cleaning Tool canister tool to perform the flush. I have tried using 2 quarts of AC flush but obviously the system still has contamination in it after flushing as it burns out the next compressor after short usage.
My technique is that I inject the clearer in the opposite direction of system flow. I do disconnect all the lines and flush at each connection.
What volume of flush is required to clean out a truck system? This next time I have 6 quarts on hand. What air pressure should I be using when I squirt the cleaner in?
Any words of wisdom would be most welcome!
