2009 unfit Honda Fit
Posted: Thu Mar 27, 2025 5:22 pm
Admittedly, I am not a A/C guy. I've been building engines and doing drive train and electrical resto work for forty years as a hobby. As a favor to my daughter, I took on her friend's 2009 Honda Fit that blows hot. The blower moves a healthy amount of air and checks out. The compressor clutch relay checks out as well. I can actuate the clutch with my OBD2 tablet, but it will not otherwise engage. I suspect the pressure switch is protecting the compressor from the following fun stuff. Fun fact #1, it is evident that some clown up-ended a can of UV dyed PAG oil into the system. There is dye sprayed around the entire engine compartment radiating around the high pressure valve. Sure enough, I was able to connect my gauges to the high pressure side, but as soon as I tried opening the valve, it sprayed out UV dyed PAG oil everywhere. Fun fact #2, the low pressure side reads a little over 150lbs! I'm picturing an expansion valve stuck open. Although I cannot be certain, I suspect the UV dye also contained a sealant that's gumming everything in the system. Fun fact #3, I cannot obtain a high side pressure due to fun fact #1.
Question for the house: Is this a total system replacement or can I salvage some parts?
