Vette conversion
Posted: Sat Apr 19, 2025 12:40 pm
by Johnsvette
Iam converting a 85 vette to 134a and the 134a
Pressure Switch for the clutch has threads that are
Too large, .390 od. My high side fitting is .375. What
Do i need to do?
Re: Vette conversion
Posted: Sat Apr 19, 2025 9:53 pm
The so-called liquid line should have a threaded connection matching that of the high-pressure switch. Sounds to me like you might have an incorrect switch.
Posted: Sun Apr 20, 2025 7:47 am
Probably has the 3/16th (smaller) service port.
Posted: Sun Apr 20, 2025 11:30 am
by Johnsvette
I measured the hp service port threads, .375"
Posted: Mon Apr 21, 2025 7:33 am
I'm not an expert on this, but the outermost dimension of the threads measures 0.375 or 3/8". I'm guessing that the actual dimension at the root of the threads is a bit smaller. So you would need a switch with that dimension.
I would order an R-134a conversion switch for an '85 Corvette with its location on the liquid line, not on the compressor, which might be a different size threading, although I'm unsure about that.
Does the car still have an R4 compressor?
Posted: Mon Apr 21, 2025 8:38 am
They only made two sizes of high-side ports on older GM vehicles, 3/8" or 7/16".
