Holds vacuum, but not a charge. Instant dump....
Posted: Sat May 03, 2025 8:19 am
by John
As stated, the system holds vacuum for a couple of hours. I charged it to 55psi before turning on the compressor and it'll hold. As soon as I engage the compressor, it does an instant dump. I shoot another can while it's running and watch the pressure come up and when I stop charging, it just drops to zero. I've shot dye in the system and can't find a leak. The compressor is clean where you'd normally see evidence of a leaking seal. I bought an electronic sniffer. It shows negative around the condenser(which is new), compressor and all connections, which have new seals. Just for the heck of it, I put the sniffer into my vents. It chirped. Is it possible for the evaporator to have such a massive leak? Why does it only leak when the compressor is running??
2007 Nissan Frontier
2024- new expansion valve, seals, dryer, pressure sensor. Blew 42dgrs
2025- new condenser, new seals. Massive leak
Re: Holds vacuum, but not a charge. Instant dump....
Posted: Sun May 18, 2025 9:02 am
Evaps are famous for leaks. It leaks when the comp is running because of the increased pressure.
Posted: Sun May 18, 2025 5:05 pm
tbirdtbird wrote: Sun May 18, 2025 9:02 am Evaps are famous for leaks. It leaks when the comp is running because of the increased pressure.
Disclaimer: I'm NOT an AC professional
Wouldn't an evaporator have about 30psi pressure while compressor is engaged and static pressure of maybe 90psi when not engaged???
Posted: Mon May 19, 2025 6:39 am
Cusser, that makes sense what you said.
After pondering this, I have to wonder if the TXV is stuck open, thus allowing the evap to see high side pressure
Posted: Wed May 21, 2025 9:03 am
Seems to me that the leak is somewhere in the (new) condenser, or in one of the joints, because the system didn't have a massive leak last year.
