2004 Mustang can't find leak
Posted: Tue May 20, 2025 1:33 pm
Hi,
I have a 2004 cobra mustang w/60k that developed an A/C leak. The pump clutch was toast, replaced it and bearing assembly. Pump is clean no sign of leak. I found the discharge hose leaking inside of a loom and had it repaired. Charged, leaked out in one day.
System would not hold a vacuum. Checked service valves, OK. Hit all connections with soapy water. After a long search I found oil/dye residue on shop floor from the condensate drain. No residue on the car, because the drain is above the exhaust and burns off. I pulled the dash (no fun) and replaced the evaporator and dryer. New o-rings, pag 46. The old evap had oil residue on it, as did the case, so it was leaking. The new Evap was pressurized, so I have to assume it doesn't leak. Now the system holds a vacuum, indicating that a leak was fixed. Charged and leaked out in one day, again.
The engine/engine bay is very clean. I have a lift and can inspect to bottom side easily. I do not have a nitrogen setup so used a partial can of 134 to pressurize and look for the leak. I cannot find any trace of oil/dye.
I'm out of ideas other than to pull off the three remaining pieces to inspect, liquid/suction hoses and condenser. Any help or guidance appreciated.
Justin
Justin
