AC has me hot!
Posted: Sat Jun 07, 2025 8:50 am
Hot under the collar that is. I need help.
20107 Ram 1500 3.6.
Checked the R1234YF pt table and i was a bit over charged. Adjusted PSI but no improvement.
Here is my issue and fustration.
Vent blows at 47 degrees on the road, hign noon in the sun, high fan and system recirculate.
If I lower the fan speed the vent temp does not change.
So why is it when im driving in 90+ Degree weather in the morning i get 47 Degrees and on my return trip at night
with the ambient air at 80 and no sun traveling same roads and speeeds the vent temp goes UP to 51?
Should it not be going down?
20107 Ram 1500 3.6.
