2012 chevy impala 3.6 no ac
Posted: Mon Jun 09, 2025 5:21 pm
So far Ive not had luck with the ac system in this car.
I can barely get 1 can of refrigerant into the system.
I know there is no blockage, I know the system holds pressure, Ive changed the expansion valve, I know the clutch engages when I turn on the AC.
Both service ports seem to be working fine. The car came with a newer looking compressor also, I changed it out with a compressor from the salvage yard.
What controls the AC compressor solenoid that lets refrigerant in? A fuse? A Relay? Another sensor like the ambient temp sensor?
How can I check that this solenoid is getting power?
Generally when the AC kicks on in a car you can hear the motor get a load on it. Nothing happens with this kicks on.
