A/C QUICKCAPS just a gimmick or actually useful?
Posted: Mon Jul 06, 2026 11:35 am
by atikovi
https://acquickcaps.com/
I'm referencing this topic from last year viewtopic.php?t=15351&sid=8f73f1b65389b ... 0b85000ea2 about the role of dust caps on the service ports and what role they play in keeping the system from leaking. It mentioned that the caps will prevent refrigerant loss even if the Schrader valves leak.
I came across an ad for A/C QUICKCAPS that pretty much says the opposite:
Traditional A/C caps don’t seal — they’re just dust covers. Even with brand-new Schrader valves, you’ll lose up to 10% of your refrigerant every year. If there’s a larger leak, you could lose it all in minutes or days — costing you $400–$1,000 or more in repairs, parts, and recharge labor.
Until now, no A/C cap could stop that.
A/C Quick Caps™ are the first and only caps engineered to fully seal refrigerant in.
No more trying to find the right cap, the one size fits all means all you need to know is your refrigerant type. It's fast, easy, and leak proof!
At $60 a pair, are they just a scam?
Re: A/C QUICKCAPS just a gimmick or actually useful?
Posted: Tue Jul 07, 2026 8:30 am
No need to spam our site with that link. A good Schrader valve and a service cap with a fresh O-ring will be all you need.
Posted: Tue Jul 07, 2026 7:09 pm
by Carguychris85
I used the metal caps on GM high side ports until they came out with a valve core that allowed a traditional schrader valve core to be used rather than that dumb nylon rubber ball. Even with the plastic cap in place those GMs could lose the full charge in a week when that junk service port failed to seal or started leaking shortly after service work was performed.
Posted: Wed Jul 08, 2026 6:09 am
With an electronic leak detector, one can readily determine if refrigerant is leaking past the caps.
https://www.ackits.com/tools/electronic ... -43-mt2734
Posted: Sun Jul 26, 2026 5:57 pm
by frank3639
If new plastic caps and schraders were all you needed and leaky schrader valves , plastic caps weren’t a huge issue and the biggest leak in Auto Air we wouldn’t be having the conversation right now. No, they’re not a gimmick they’re leak proof and should be the industry standard. Did you know that new schrader valves are considered good if they only lose up to 5% of the systems refrigerant annually? As they age and in extreme cold the seals on schrader valves shrink up causing you to lose even more refrigerant.
It’s best practice to change the system’s schrader valves and then install A/C Quickcaps when finished. Why would you use a plastic cap that will allow refrigerant to leak past it over time when you can use a cap that holds 100% of the vehicles refrigerant even without a schrader valve in the service port. (Without Schrader for testing purposes only) they also prevent fluid from entering the service port leading to rust / corrosion that ruins Schrader valves as well as service port fittings.
Since I started using A/C Quickcaps in my shop as standard practice my comebacks are down 90%. Which has led to happier customers, techs and myself as shop owner not having to warranty refrigerant that costs $10.00-60.00 per pound or not getting yelled at by angry customers that they aren’t paying for schrader valves and we should of seen that leaking at time of service often times 4-5 months ago. There are absolutely ZERO reasons that plastic caps are better than A/C Quickcaps. Not to mention finding the correct plastic caps cap often times be a real pain! There are hundreds of different Caps and A/C Quickcaps eliminates that aggravation as well . Two sets of caps covers every vehicle there is! Not to mention A/C Quickcaps look great and really dresses up your engine bay,
Posted: Mon Jul 27, 2026 9:21 am
I agree that there are different-sized caps and schraeders. Maybe cost-effective for a shop at $60, and maybe worth it for 1234yf. Especially as an upsell for a shop.
But my three vehicles are R134a, and one on R-12.
Posted: Wed Jul 29, 2026 3:18 am
Not being disagreeable, just adding my two-cents worth to the conversation.
I have never experienced a leaky metal or plastic service-port cap.
That said, modern materials and designs have undoubtedly improved on the lowly plastic cap, its durability, sealing abilities, appearance, and universality, albeit at a price. I'm always looking for new-and-improved MVAC products, and I'll give these a try as well.
Posted: Wed Jul 29, 2026 6:39 am
JohnHere wrote: Wed Jul 29, 2026 3:18 am I have never experienced a leaky metal or plastic service-port cap.
I have experienced leaky ones, primarily from broken rubber seal. I even experienced this on a 1966-era refrigerator which stopped cooling in the early 1980s; it used R-12 and had a metal schraeder cap so I just added a can of R-12. A couple of weeks later it stopped cooling again, and this time I added another can of R-12 and replaced the cap with a metal vehicle AC cap to fix it. More recently, I had a low side R134a plastic cap leak on my 1998 Frontier.
JohnHere wrote: Wed Jul 29, 2026 3:18 am I'm always looking for new-and-improved MVAC products, and I'll give these a try as well.
There's a competitor to these, called FreezeCap
Posted: Wed Jul 29, 2026 7:26 am
I stand behind what I said before. A good cap with a new O-ring & Schrader valve should be all that is needed. If someone wants to spend money on gadgets. Feel free.
43-mt9662
