Using R134 to test in an R-12 system
Posted: Fri Jul 14, 2017 10:12 am
I've got all new AC components in my 1992 Buick - nothing reused. I hooked everything back together and pulled a vacuum but it will not hold overnight. I have already added R12 Mineral oil and UV Dye into the system. I have R12 that I want to recharge with eventually.
I then used plain shop air to pressurize the system up to 80 psi - then I used soapy water on all of the connections to see if they would bubble up....I can't find a leak..
Can I use R134 to leak test with even though I have Mineral oil in the system? as long as I don't turn on the compressor?
