Acura RDX AC Acting Strange
Posted: Wed Aug 03, 2016 5:02 pm
The AC in my wife's Acura RDX has been acting a bit strange over the last year. If the ambient temperature is over 90degF the system will refuse to even run. At temperatures of around 90F and below it works and blows very cold air...as long as the car keeps moving it will continue to work, but if I get stuck in traffic the compressor will shut off and stays off. If I park the car and let it sit for a while (overnight usually) the AC will work again. I initially suspected the condenser coil fan, but it comes on at high speed anytime the AC is turned on...even if the compressor doesn't actually engage.
Some extra background...2 years ago, the AC stopped working and the compressor wouldn't spin. I diagnosed it to a failed clutch coil relay. Replaced the relay and it worked fine until the next year. When the AC stopped working again and the relay wasn't the problem I started looking around online. I found several posts talking about failed clutch coils and then found that the part was given an extended warranty from Acura but that ran out a couple years ago. I bought a new coil and installed it, but that didn't fix the problem. My fault for throwing parts at a problem instead of diagnosing them first. I gave up and took the car to a local mechanic...they evacuated the system and told me it was about 1lb low and refilled it to what they said was the correct volume...though when I asked the guy what it was filled to, his answer was vague so I don't know how much he actually put in. Obviously this didn't fix the problem or I wouldn't be creating a new post.
So, here's where the car sits today. If it is cool outside in the morning, the AC works and these are the pressures I am reading:
Low Side: 44psi
High Side: 110psi
After the system warms up:
Low Side: 32psi
High Side: 123psi
After everything gets too hot and the compressor stops:
High and Low Side: 140psi
The only thing I can think of is that it doesn't have enough refrigerant which allows the system to overheat too quickly/easily. Any ideas?
Low Side: 44psi
High Side: 110psi
Low Side: 32psi
High Side: 123psi
