Clutch squeals something awful
Posted: Mon Aug 08, 2016 7:09 pm
On 2011 1/2 ton dodge pickup with 3.7L V6. This happens when AC has not been running (no built up head pressure). Clutch attempts to engage, input shaft to compressor is turning slowly for a few seconds, squealing badly, then engagement happens, sometimes chirping happens after engagement, it seems to be slipping.
Vehicle has 38,000 miles. Compressor seems to be binding, turning compressor by hand seems to require more force than it should, even after high pressure has had time to bleed down. It seems as if the input should turn fairly easily for a turn or two, if no pressure exists.
When clutch is not slipping, compressor is whisper quiet, system cools normally. Vehicle belongs to a friend of my wife's. I hate to give her the bad news, but it sure seems like the compressor's heading south.
Does this seem familiar to any one? Thanks, Drake.
