2008 Ford Ranger Plugged Orifice?
Posted: Fri May 11, 2018 10:20 am
Just bought a used Ranger 4.0l. A/C
Not cooling. Gauge says low, clutch not engaging. Started charging and eventually the clutch started cycling on and off. After 12 oz of 134A still no cooling. started adding more 134A and the the check valve on the compressor started blowing. Is it possible that the Orifice is plugged? A/C was set to High.
