Compressor not cycling - Pressures are steady
Posted: Mon May 30, 2016 10:28 am
I have a 99 F250 7.3 Powerstroke that had a leak in the discharge hose. I replaced the hose, vac'ed the system and then charged it.
The ambient temp was 80 when these pressures were taken.
The compressor is not cycling off so I think this means the low side should be under suction. If this is the case, the low side pressure is probably too high.
The high side sits around 100psi when the AC is off but when turn on it builds to 175 and remains there.
I charged the system with a 30lb tank so i relied on the pressure to know when it was full. The system take over 2lbs of r134a but the tank feels a good bit lighter and I think it may have been overcharged.
The AC is working great but I've noticed a weird noise under the hood when I first start the engine which is another reason I am concerned.
I'm wondering if this behavior could be caused by a failing compressor that isn't building the correct pressures or a blocked orifice tube.
I'm just a shade tree mechanic so any help from the more experienced would be greatly appreciated.
