2006 Saturn Vue cooling at idle
Re: 2006 Saturn Vue cooling at idle
The sensor is on the high side line someplace. AC Delco part number 1551343
Again, a Mitchell subscription can be a big help. You can screen shot the wiring diagrams & save them, that alone is worth the $20 charge
https://eautorepair.net/Marketing/Default.asp
atikovi
Post by atikovi »
What brand compressor?
satvue
Post by satvue »
I've tried 2 remanufactured compressors and one labeled NEW, all same results. I put a new scroll valve in the initial compressor hoping that was the issue, no dice.
satvue
Post by satvue »
bohica2xo wrote:The sensor is on the high side line someplace. AC Delco part number 1551343
I'll give the Mitchell subscription a shot, Thank You.
satvue
Post by satvue »
Changed out the highside switch, no change. If I hold the throttle down at 1500rpm, temp immediately drops, I let off temp immediately goes back up. Any other ideas?
atikovi
Post by atikovi »
satvue wrote:If I hold the throttle down at 1500rpm, temp immediately drops, I let off temp immediately goes back up.
That's opposite of what you say in your title.
satvue
Post by satvue »
Do you typically only read thread titles?
satvue
Re: 2006 Saturn Vue NOT cooling at idle
Post by satvue »
My apologies for the misleading thread title. I don't see an option to change the title. I'll see if I can get a mod to adjust it.
atikovi
Post by atikovi »
No but the facts stated here are contradictory. Regardless, if there is normal cooling at above idle that drops to little or no cooling at idle speed, it points to a bad control valve in the compressor. Or at least it has on 3 of my last Vues in which I replaced the valve.
satvue
Post by satvue »
New control/scroll valve was the first thing I did, didnt help.
Locked
