People,
2001 Honda Civic EX, blowing warm (ambient) air fro ac, the guages read 125 psi for BOTH low and high side. No activity at the comp. Does this typically mean a bad comp, people?
Strange PSI's in AC system, no cold AC
Re: Strange PSI's in AC system, no cold AC
It means there is probably no 12 volts getting to the clutch
Thanks, Doug. So, just to make sure, I went out there again, and started the engine, waited and waited about 4-5 minutes not expecting any activity with the clutch, then bam- clutch kicked in. What the heck?? The vents started blowing cold, I waited some more. Clutch ran for say, 3-4 minutes steady , blowing cold. then it stopped.
Low psi side showed psi's going up and up, from 40 to about 90-100 psi. Waited another 3-4 minutes, still clutch did not kick on. I was not happy. Vents were blowing warm again (its about 88 here).
What could this mean?
First thing is to verify correct refrigerant charge.
Check and adjust the clutch gap.
I agree, Doug, but just noticed on the guages after starting the car up again, the high side is now so wacky, the needle is vibrating violently, back/forth, so fast I cant even read it, about from 200 psi to 350!! Never seen this before! Also, loud rattling noises coming from the comp. After a few minutes the needle slowed down, but still vibrating from 225-300 psi or so. What do you say to that, people? Comp starting to explode, right?
Thanks, Bo, but with my recent post above, should I still suspect the clutch gap?bohica2xo wrote:Check and adjust the clutch gap.
Some of the older systems did have a bouncing needle on the gauge. I used a set of gauges that had glycinerin in them to cut down on that.
The un-predictable compressor engagement is usually a clutch gap.
The pulsing is a scroll compressor thing. Increase the engine speed to 1800+ rpm, and see if the pulses are less severe.
Thanks, good to know, Doug and Bo. My guage set is 15+ yrs old, and never bounced once. I suspect this comp is the cause of the bounce, which is so fast, so severe, its more like watching an old prop on those WW II planes.
But what should we make of the grinding/rattling sounds? I wouldnt mind trying a new clutch, if yous suggest.........Makes sense to first do a simple clutch gap check, with a guage?
