my ac blows hot on freeway, Cool in town what could it be.?.and Cool in park..?
Compressor has been changed yet still...
2012 Mercedes GLK 350 - A/C Cooling problem
Re: 2012 Mercedes GLK 350 - A/C Cooling problem
Start looking at the metering device. If possible, tape a gauge set onto the windshield and give us the readings.
Metering device? You mean the manifold gauge or what?
Negative. I am speaking of the TXV or orfice tube. There are the devices that allow refrigerant to flow into the evaporator.forumoto wrote:Metering device? You mean the manifold gauge or what?
Expensive tool like which type? Are you thinking about scan tool? I have autel scan tool. Which can analyze the lice data pid of the A/C module and Engine Module, all that matter is the sensors to select for this info to display and record.
