Im reading that my TA likely has a v7 ac compressor. I have been debating whether to try and troubleshoot the TA's compressor clutch , compressor bearing, ac idler pulley etc. All these parts Im pretty sure are original. Id spend some time troubleshooting and even if I repair and fix , Id still have 25 year old compresssor. I thought best approach would be to install new compressor - which would come with new pulley bearing and new ac clutch. I can also replace ac accumulator/drier and orifice tube. I have harbor freight vacuum pump and ac gauges and some cans of R134a. So, I can discharge the system , pull vacuum and recharge.
What would be the ackits part numbers for new ac compressor, new accumulator and new orifice tube (likely need new line seals and some compressor oil?) - or does ackits have a kit ? How's the ackits quality versus other compressors out there ? I can see four seasons, GPD, UAC- though I have not really heard of any of these suppliers. Thanks for any help/advice
