2005 Subaru WRX (Actually a Saab 9-2x, but it's a WRX under the skin). AC has been working fine for years but recently does a lot of short-cycling when driving >2000 rpms. Put the gauges on tonight to see what's going on.
- At idle, ~30psi low, ~225 high at 85F ambient. Sounds about right, correct?
- Revving past 2000 rpm, low drops to ~20psi and high shoots to ~400psi, then one or the other limit switches cuts off the compressor
- (From reading most low switches are around 20psi and high is about 420psi)
- While driving this results in short-cycling like every 20 seconds
- There's a bit of a chirp coming from the compressor when this happens, but figured it may have to do with the high pressures
With a limited understanding of how the AC compressor actually manages higher RPMs, I have to believe I either have a problem with
(1) The AC compressor itself - whatever inside manages or regulates pumping when it's spinning faster
or
(2) an obstruction in the system that causes high high side pressures as the compressor is pumping more volume/
Thoughts? Any advice is appreciated
