Hi.
Hopefully someone can help me with this. This seems like a very informative site for automotive AC.
I have a 2000 Grand cherokee I've done an LS1 swap with a front runner pulley and a Sanden AC pump and condenser. My question is if I make adapter fittings for the firewall fittings to AN fittings will the stock under the dash evaporater work with the aftermarket components?
Factory AC with Aftermarket Compressor
Re: Factory AC with Aftermarket Compressor
I don't see any obvious reasons why your setup wouldn't work. Charge the system to the factory specifications and see how it performs.
The original specs for your Jeep are 24 ounces net weight of R-134a, and 5.75 fluid ounces of PAG-46, unless the Sanden compressor requires more oil than that.
Well that is great news. I'm not able to find an adapter to go from factory fittings to AN hose so I'll have some time and effort doing that and want to be sure I'm going in the right direction.
Thanks for your help!
The best option is to have custom hoses made. Too many adapted connections are just areas for more leaks. No reason an aftermarket compressor will nto work with your components. Be sure you're "not" using a variable displacement Sanden is the only hic-up I see.
Thanks Tim I bought the compressor so long ago I'll have to check to see what I actually bought. I've made my own ac hoses in the past I actually have an ac line crimper for sizes -6, '8, & -10.
I'll try to send pics of my compressor tag and the line I have to adapt to. For some reason this post won't let me attach them.
Thanks for your help Tim
