How much vacuum
Mogman
Re: How much vacuum
Post by Mogman »
OK, I did a little more reading, it does have a umHg, cool!
andrew vanis
Re: How much vacuum
Post by andrew vanis »
Which one are you using, I'm in the middle of choosing one so would like you consider it as an option.
Mogman
Re: How much vacuum
Post by Mogman »
This is the one I picked up, I have no idea how accurate it is, if it meets the specs listed it will do.
andrew vanis
Re: How much vacuum
Thanks for that info, it is one of the one's I have on order, it is a diff "brand" but the same unit - physically and specs.
andrew vanis
Re: How much vacuum
Mogman wrote: Sat Oct 21, 2023 8:26 am This is the one I picked up, I have no idea how accurate it is, if it meets the specs listed it will do.
FWIW, the version of that I got had the highest outrageous reading in this list.
https://www.autoacforum.com/viewtopic.p ... 336#p28336
andrew vanis
Re: How much vacuum
andrew vanis wrote: Mon Oct 23, 2023 7:17 pm
FWIW2 - turns out I got a second one, the second one also had the outrageous high reading compared to others. 0/2 on that one :(....hope yours is reading better.
