Expansion valve
Daniel
Expansion valve
Post by Daniel »
Hallow to all. How to remove an expansion valve on a 2008 BMW 328i
Re: Expansion valve
Google it. There are You tubes on this.
Re: Expansion valve
Step 1. Disconnect negative battery terminal
Step 2. Recover refrigerant
Google
Re: Expansion valve
But Google tracks my searches. Happy Monday all. :)
Re: Expansion valve
Use a private window
Daniel
Re: Expansion valve
Post by Daniel »
I was able to move it with a home tool i make. Thank for your help
Daniel
Re: Expansion valve
Post by Daniel »
I need a replacement valve I use the original for dummy to flushing the Evaporator
Re: Expansion valve
Al9 wrote:Your best bet on finding one is the second hand market. Trying to source a brand new one for such an old vehicle will likely yield poorly assembled, and who knows what's inside the power head (=how much oil it returns to the compressor in critical operating conditions), Chinese garbage.
So what would the dealer do? Use a second hand valve? No they would use a quality replacement.
Re: Expansion valve
Daniel wrote:How to remove an expansion valve on a 2008 BMW 328i
Al9 wrote:Trying to source a brand new one for such an old vehicle will likely yield poorly assembled, and who knows what's inside the power head , Chinese garbage.
Wow - all 6 of my vehicles are 2005 or older !!!!
Re: Expansion valve
Supplier lists as non-aftermarket version.
https://www.ackits.com/exp-valve-bmw-12 ... d=31-31191
