Tim,
1) do you have any thermostat switches (with a cap tube) that have a 10° or 20° differential? MY switch now has a 40° diff which is absurd (custom system using VA components and your comp). Determining the diff rating on these things is harder than it should be
2) do you have any 12oz side can tappers (with 1/4 flare fittings) with an isolation valve to block off the can if only a portion is used? All we can get now are the foolish self sealing cans which do not work. This is for people who bring their own cans for us to use. We are hoarding the 30 pounders, and don't want to use them unless we charge a huge system such as a suburban or something
Thx
Dave
Parts questions for Tim
