Capacity? 2016 Silverado
andrew vanis
Post by andrew vanis »
What's the proper refrigerant capacity for this 2016 Silverado I'm checking out for a friend? Checking online shows several different results.
Any hints on this low performing system? It'll be my first domestic. Plan is to evacuate and fill to proper capacity.
Andy
VIN 1GCRCNEC8GZ165539
Model Year: 2016
Make: CHEVROLET
Model: Silverado
Body Class: Pickup
Series: 1500
Trim: Work Truck/LS/Fleet/Base
Gross Vehicle Weight Rating: Class 2E: 6,001 - 7,000 lb (2,722 - 3,175 kg)
Axles:
Engine Displacement (L): 5.3
Axle Configuration:
Drive Type: 4x2
Cylinders: 8
Primary Fuel Type: Gasoline
Engine Model: L83 - SIDI, VVT, AFM, E85 MAX, Aluminum.
Re: Capacity? 2016 Silverado
R-134a
Refrigerant Charge
0.6 kg 1.4 lb
andrew vanis
Thanks Tim!
Less than 2 cans, surprising
Always check the sticker in Eng Bay. That was AllData's listed capacity.
andrew vanis
Tim wrote: Fri Jun 14, 2024 6:42 am Always check the sticker in Eng Bay. That was AllData's listed capacity.
Looked hard for the sticker. None to be found :(. Where are they typically and I'll look again.
GM mostly placed them on the Radiator support. All data is pretty good; run with it. No need to over think that with data super close. :)
andrew vanis
No sticker found :-/
And it didn't matter.
Gauges showed good pressure and there was some cooling (and I was short on time) so I was just going to "top it off" as long as the temp delta kept improving.
Luckily, somehow, it came up that it wasn't blowing that hard and friend said yeah, not as hard as it used to - I found t the e cabin air filter caked with dust (lives in rural area).
Took the cabin filter out (with the AC off so not to suck any dislodged dust into the evap) and was getting full air flow and a nice cool 45F delta between ambient and center vent with all doors open on a 103F day.
I'm used to older cars without cabin air filters. This that me to check that before adjusting refrigerant.
SO glad I didn't overfill his system!
andrew vanis
Catching up on posts, I just see that maybe what happened was my subconscious remembered this posts I read a few days ago... Knowledge is power! Thanks Tim for breathing a platform to share knowledge.
viewtopic.php?t=15064
Hemispheres wrote: Wed Jun 19, 2024 5:02 amSo last night I changed my cabin air filter and now I've got cold air again. The filter was filled with bits and pieces of leaves and dust.
