Will a Sanden 508 be adequate?
jeepsj
Post by jeepsj »
So the whole 87 Chevy Dually project just took a turn. I'm upgrading to a serpentine belt and part of the kit has a mount for a R4. Well I have never been a fan of those, and there is a kit for mounting a 508 into the R4 brackets. Will the 508 be adequate for cooling the crew cab in AZ heat? Will the 508 work with the cycling OT setup?
99 Jeep XJ
87 Chevy CC Dually
Re: Will a Sanden 508 be adequate?
Might look at using the 510. Many have the same mounting tabs as the 508 but larger capacity. 508 should still do the trick.
jeepsj
Post by jeepsj »
Thanks Tim. Do you have such a 510? I'm done with parts store failures. It will need to have a serpentine style pulley. If this works, I'll be doing this same swap on my diesel Wagoneer when it gets back on the road.
99 Jeep XJ
87 Chevy CC Dually
I have the after market version. Just make sure you have a little more room off the back of the compressor. 510 is a little longer.
http://www.ackits.com/comp-sd5h16-9120- ... d=20-10115
jeepsj
Post by jeepsj »
None with the serp pulley?
99 Jeep XJ
87 Chevy CC Dually
