I had a post in 2007 http://www.autoacforum.com/messageview. ... adid=17957 and I'm repairing the system after an apparent compressor failure (stuck internal reed valve suspected) so I'm going to flush the system.
Since this is basically a hybrid system (everything OEM except compressor and condenser) and yes I did use the POA valve set for R134. For some reason I can't find my notes on the quantity of oil I used. Everything will be flushed except for the compressor and drier which of course are new. I plan to use 6 oz. (PAG 46) in the compressor, 3 oz. for the drier/lines but am uncertain about the rest. Can anyone help me on this one? Thanks
69 Camaro Back Again from 2007...
Re: 69 Camaro Back Again from 2007...
I do not have the oil quantity requirement for your system, but I would GUESS it needs about 6-8 ounces of oil. So you may be good with your 9 oz. plan.
I'm about to go out to take it all apart and flush so maybe someone will have another recommendation later on before I seal everything. Thanks for your input though. (I seem to recall your user name from years ago)
Yup, been around so long, I thought the "grumpy old man" avatar fit.
If you have questions ask away, or maybe start a new topic.
Welcome Big, thanks for your comments.
start new topic here............ Yes, if you would like to.
Nice Discussion Is Going on Here..... Not much to discuss, you are responding to a very old post.
Any One Can Start The New Topic..... Sure they can.
